o rings
I am looking for a source of 3" OD or ID EPDM o rings, 1/16 thick.
If anyone has a source, I sure would appreciate it. davelynds@eastlink.ca |
check you local NAPA store. could be that easy.
You could call your local hydraulics repair shop- 3" is a common hydraulic cylinder size and O rings are used to seal the ends of some types of cylinders.
1/16 is pretty thin though... |
