What kind of sawdust is best, hardwood or softwood? And what is the ideal proportion to mix it?
Plus, what size? Chainsaw chips, drill chips, rough circular saw dust, fine dust...
BTW...way back in the before time, I used to use Arco Graphite motor oil. Always worked fine for me, even in my Triumph 650 with a wet clutch. Only problem was that it was really messy when oil would spray onto my good clothes... https://www.museumofamericanspeed.com...ix/01-398S.JPG |
Huh. Well, that's what I'm talking about. There must be a reason they don't use it anymore.
The reason I'm rebuilding it is to put in taller gears, and final drive, and an LSD. While it's out I have an aluminum flywheel, and stronger clutch to put in. |
I'd imagine if graphite was a beneficial additive it'd already be in one of the higher quality, higher priced, or race-bred and race-targeted brands.
the lack thereof should answer the question. There are some with Molybdenum Disulfide in there, but not much. It's a "little goes a long way" situation. |
