Is all ATF +4 synthetic?
Hey guys. This was inspired by bowtieguy's thread here: https://www.gassavers.org/showthread.php?t=12182
Instead of his question, I have a few minor concerns regarding the use of Valvoline's ATF +4 in my '99 Stratus. https://www.valvoline.com/products/co...ssion-fluid/32 The Stratus has a 41TE transmission and probably came with ATF +3, I believe, but not sure. That is, unless all Stratus' models by that year were incorporating ATF +4, but I don't know what year that type of ATF came out? I may have been the only person to service the transmission on this car(which was a filter change/fluid top off with "ATF+4", a store brand version at around 95k), so it at the very least has a marginal amount 'newer' ATF fluid and currently has over 100k on the majority of the ATF currently in the system. I was thinking of using the Valvoline product. Amongst its claims is: Officially licensed and Chrysler approved. Specs: https://www.valvoline.com/pdf/Valvoline_ATFplus4.pdf Thoughts of doing a 'mini' flush; simply allowing the cooler line to drain and add new fluid as needed until all is new fluid/have gone through the total number of Quarts called for, and that way replace all of the fluid myself for about $80(fluid, filter, gasket)? I'm having some symptoms of RPM drop entering 4th gear and I'm suspecting the torque converter. ADDED: Found this https://www.centerforqa.com/ |
I know ATF+4 was around by 2001...that's the year I picked up an '89 Dodge Caravan, with the first electronic controlled transmission (and what an ordeal THAT was!). I spent a lot of time researching how to make these transmissions work. That was the recommended ATF. Like other types of ATF, they are backward-compatible.
Yes, the ATF+4 is synthetic and backwards compatible with the ATF+3.
If you put any other fluid in there you will have trouble with the tranny. The Valvoline ATF+4 is good and cheaper than the Mopar brand the last time I bought it anyway. |
Thanks guys. I went ahead and ordered the Wix tranny filter kit:
https://www.oreillyauto.com/site/c/de...3230&ppt=C0073 It appears to come with a new o-ring, I also ordered the Fel-Pro gasket(which apparently I may not need as the Wix kit looks to include one according to the picture...ugh wasted $5.99 lol): https://www.oreillyauto.com/site/c/de...3233&ppt=C0073 ...both from O-Reilly locally for about $18 in total. They also sell the Valvoline ATF+4 for $5.99/Q. So, I figure since my car calls for 9.2q on a complete refill(4.2 on a pan drop/top off), I can buy 10 Quarts and do the 'flush' via the method described below: Link location: https://www.allpar.com/eek/atf.html Quote:
ATF+4 works when ATF+3 is specified, and is synthetic. It will work better, in fact. How many miles on the '89 Caravan? That may tell you more.
You will do better to do a proper transmission service to flush the tranny and change ALL the fluid, filter & gasket all at the same time. Costs a little more but is well worth it, and may help fix the torque converter issues depending on what is actually wrong with it. The method you cite will leave about 10-15% of original fluid in the vehicle. This is one thing I leave to the pros, personally. Dodge transmissions are notorious on that vehicle for being pieces of junk, and Dodge knew it. I had my '97 rebuilt by a former Dodge employee of 30 years and it worked better than the original. |
The car I have was a "dealer owned" car during its first 25k or so. I may be able to pull their service records from the local dealer, from there my sister had it. She drove it until 89k when I purchased it, and its been almost 30k since I changed the filter/fluid @ 95k, and I believe my mechanic used O'Reilly's ATF +4. I know other store brands list '15k service interval'.
I'd rather do this myself this once for about $80 since its my 2nd car and not my daily driver. So, when it comes due again I'll know if what I did helped the symptoms or not, and could choose to just do it again this way. I'd definitely not want to flush the system with anything other than pressure generated from a general flow rate. Especially, am I fearful of running that 'backwards' flush, since I've heard bad things about cars like my Stratus that didn't get regular service intervals finally having a flush on this side of 100k without prior servicing. |
By the way, should I worry about applying any RTV sealant or any type of liquid sealant when re-installing the pan w/ new gasket?
I am rather paranoid about automatic transmission care. In your situation I would change the filter and top off, then every 5,000 or 10,000 miles I'd drain and fill the transmission again, for a long time. This would replace most of the fluid gently, avoiding potentially shocking the system and breaking free any built-up crud. It may be a superstition, I don't know.
I'd rather do it that way, if I'm going to service it that often for 'a while'. |
There is an inexpensive electric pump that can do that job. However, is it possible to install a drain plug?
Also, I don't know if it's appropriate to exercise my level of paranoia and superstition. |
