Does EGR valve matter?
I just noticed that along with my VTEC-E swap into my '95 Civic CX they put a cover over the EGR valve, (blanked it off), and there is no box with the solenoid and vacuum control valve, does it matter? I've also got a P08 ECU, non-stock exhaust manifold (4 into 2), with 4 wire 02 sensor. Power seems good, idle is 750 rpm (a little fluctuation), but mpg is terrible, definitely worse than the original 16 valve Canadian CX engine. I just got a P07 ECU and I'm going to get a 5 wire 02 sensor, hopefully with the stock manifold, does the EGR valve matter?
Re: Does EGR valve matter?
Exhaust Gas Recirculation is mostly for NOx emissions control. However, EGR at part load improves fuel economy because it reduces manifold vacuum and associated throttling losses.
If you're missing any emission control systems in that car, the mileage will definitely suffer. Ask them why they removed that part and perhaps ask them to put it back since it's necessary to pass emissions.. How about a link to the company that did the install?
Not to mention, depending upon where you live, you may not even be able to register the car if you have periodic inspections which include emissions testing.
In my Civic, EGR is also used to control knocking, as it brings combustion temperature down.
This appart from the already mentioned NOx decrease. So, yes, EGR matters. |
Ok EGR matters, I'll put one back on.
I don't have a link to the shop that did the swap but their name is "Optional Performance" in Toronto, Canada. |
EGR is purely an emissions control device and a bad one at that. Of 3 cars that I've tried disabling EGR, all 3 have gained MPGs in the process. Some cars have a temperature sensor in the EGR pipe that will register a fault if the pipe doesn't heat up periodically. You will need EGR to pass emissions test.
https://www.planetcampbell.us/AFR_Emissions_Graph.jpg |
