While I have the valve cover off...
This weekend, I was planning on adjusting the valves on my VX for the first time. While I'm at it, I will check (or replace) the timing belt/tensioner and water pump.
Anything else I should do while I'm in there? I'd like to not have to open it up again right away; I'll be replacing my rather leaky valve cover gasket. What other preventive maintenance items can be taken care of with relatively little special equipment? I might add this is my first time in an engine, but I'll be taking my time (and I have the Helm's manual.) (On a side note, I think my input shaft bearing is bad. It might be a while before I'm able to drop the tranny for that one.. anything else I should do while I have THAT out? Rear main seal, etc?) |
Re: While I have the valve cover off...
Ended up going pretty well... the old gasket was very brittle and actually broke when I pulled it out.
About half the valves needed adjustment... I used a 10mm wrench and a screwdriver, but I can see how the "valve lash tool" could be a big help. I had to do a couple valves more than once when the screw went out of adjustment as I tightened the jam nut. I also did a compression test... 190 across all four cylinders! Though it did take a good 10-12 cranks to get up to pressure. |
