Civic Vx Owner : Upshift light question
I have a Californa 92 vx that I would like to install a upshift light on it. I belive the only difference between a California 92 vx and a Fed vx is the (ECU/Upshift light) as it came with a 5-wires O2 sensor already. I've already convert it over to lean burn with a Fed ECU but I now have a upshift light cluster and it doesn't seem to be working. Do you guys know if there's something else I have to do for it to work properly or is it just a slap on and work thing. Thanks for any reply.
Re: Civic Vx Owner : Upshift light question
LOL what the hell have I been smoking, I forgot that I already installed my factory cruise control and the upshift light is already taken.
^ Hah. I have a factory cruise retrofit also, but intend to have both indicators in my cluster - though my upshift light will be located in the spot where it is on a 49-state CX (top right indicator). This will require a diode in-line along the wires that will both use the same clutch switch.
In answer to your question, I suspect that you will need to run wiring to your clutch and to the cluster to get it to work, even on your former CA VX (ie., it's not pre-wired). |
