$3000 Tax Credit
I have to add something I overlooked -- someone brought to my attention today that a $3000 tax credit comes with hybrids. That helps the first year and cuts the time it "pays for itself" -- so it would depend on a persons tax return results...
RH77 |
Re: $3000 Tax Credit
I believe it's a credit.
i am a chinese,i know how to reply you with chinese.but my english is not well enough,so could i use chinese?"不会对你的发动机造成伤害,因为润滑油在起作用。但是相对而言,这样会浪费掉一部分能量 ,因为被停的那几个汽缸仍然??"
Translated to English via babelfish:
I'm considering a all off system for my automatic subaru.
When slowing down flip the switch and cut off the signal line to all the injectors. At the same time it would need to turn on fake sensor signals so the computer thinks everything is normal. Cutting back the number of cylinders seems like it would have adverse effects. My car runs like crap if it is missing on one or two cylinders. The car would likely run a little rich as the disable cylinders are pumping fresh air over your O2 sensor. |
if it makes any difference i had a car with a bad cylinder and it ran just as bad with one injector unplugged (v4)
