can you change the final drive ratio 95 accord automatic
I would need to know which honda transmission would have the tallest final drive to lower the rpm at 60mph from 2,500 rpm to below 2,000 rpm
Re: can you change the final drive ratio 95 accord automatic
Don't forget that an automatic will downshift if you have to open the throttle too much, so ratios for FE are a balancing act.
