very informative graphs
https://www.fuelly.com/attachments/fo...96d30ce729.jpg
https://www.fuelly.com/attachments/fo...cf3e5b3b63.jpg SOURCE: Adapted from Amann (1991). https://www.fuelly.com/attachments/fo...8d4db064c5.jpg SOURCE: Adapted from Ford Motor Company (1991). but this section explains the vtec-e homo/stratified charge. Automotive Fuel Economy: How Far Can We Go? i had this paperback for free ages ago yet i forgot to share it. being naive i dont know if anyone has this:o |
Re: very informative graphs
What a coincidence! Just a little while ago I was thinking of finding or making something like that, but not as good. These are great!
Thanks for posting these!
The most surprising thing for me on the top graph was the friction loss. I expected it to be low at idle and high at full load. |
That isn't surprising because the graph is in percent of fuel energy. That's why BSFC improves closer to full load, and why I prefer low RPM with open throttle.
Also, reciprocating loss is missing, but then the graphs don't deal in RPM. |
this is from early 90's as the tittle "Automotive Fuel Economy: How Far Can We Go?" i have the pdf. i dont have a host for file sharing though. it has some good stuff in it.
Ok, I think I get it now. So if we burn 1 cup of gas in an engine at idle, it will run for quite a long time and it will turn so many rotations that the relatively small frictional losses per crank rotation will be additive and will be very significant.
Whereas if we run a cup of gas through an engine on a dyno at near full load, it will not run very long (fewer revolutions) so the frictional losses add up to less even though they are greater per revolution. |
Seems to be (at least partially) viewable online at
https://books.nap.edu/openbook.php?isbn=0309045304 |
The book is at https://www.multiupload.com/FHNOBGOUXQ
i have a bunch of statistics, CAFE stuff, general.... one could say boring. ill look for the studies and effects of etc etc, i know i have them in my back up hd. in the meantime i give CAFE 2008
https://www.fuelly.com/attachments/fo...f11dcb3cf3.jpg |
