-   Introduce Yourself - New member Welcome (http://www.fuelly.com/forums/f6/)
-   -   Hi I am Russell (http://www.fuelly.com/forums/f6/hi-i-am-russell-13413.html)
roger2010 03-24-2011 12:06 PM
Hi I am Russell
I drive a s-10 with a 4.3 liter in it, I didn't realize when I brought it how poor of mpg it gets? I change my driving habits, car pool more and not drive as much.
I know to slow down and run with low rpm. I am wondering if a cool air filter could help? Or any other simple products that could help me increase mpg, thank you
IndyFetch 03-24-2011 04:09 PM
Re: Hi I am Russell
Welcome to the site.
Many members on this site have found that cold air actually hurts mpg. I have a scangauge, which can show intake air temperature. All other factors held constant (well, as close as I can get), I could see as much as a 2 mpg difference between 100-degree intake air and 40-degree intake air in my Civic Si. I have a short-ram intake, which is less restrictive, but does not supply much colder intake air than the stock intake. I noticed more power and similar mileage.
theholycow 03-24-2011 04:49 PM
Re: Hi I am Russell
Generally, someone who is driving with a concern for fuel economy will be unable to notice or measure any result from an upgraded intake.
What year is your truck? Is it 2WD or 4WD?
GasSavers_BEEF 03-25-2011 03:19 AM
Re: Hi I am Russell
I would say to get a scangauge (or ultragauge) to show you your mileage in real time.
either of these can be found on the web with a simple google search. though I am a big fan of the scangauge, I will say the ultragauge is less than half the price of it at $60-$70. much cheaper than some of the CAIs I have seen around.
also, have you aired up the tires. there is a maximum sidewall pressure printed on the tire itself. it is usually much higher than the 32 or so the manufacturer of the car recommends. as long as you stay under the max sidewall pressure, you will be fine. you will probably be suprised what a difference this small modification will make and if you have an air compressor, it's free. costs me a quarter at my local convenience stor
IndyFetch 03-25-2011 09:06 AM
Re: Hi I am Russell
We should probably mention that the Scangauge will only work if your truck is OBD II-compatible. This means 1996 and newer for most vehicles.
GasSavers_BEEF 03-25-2011 09:34 AM
Re: Hi I am Russell
my bad, you are right about that. I forget about that sometimes.
(the whole obd-2 and 1996 and newer thing)
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
