Honda Civic VX 5 Wire conversion for sale
I have a conversion kit for sale, this will convert your CA VX, or any other 92-95 Civic with a VX engine to a 5 wire wide band oxygen sensor. Average fuel eco. on my 94 VX CA was 46mpg (Yours may vary).
What comes with the kit: 1. 37820-P07-A00 Fed. 48 state ECU 2. Civic VX 5 wire oxygen sensor, pulled from a civic HX with 120k miles on it. 3. 5 wire harness, with all the pin outs labeled to install and tap into the ECU. 4. the EGR control units (all you need is the mount and cover, see link below). https://www.hondaautomotiveparts.com/...ONTROL+%282%29 https://www.fuelly.com/attachments/fo...d1b4b0e90f.jpg $250 Text if interested, or call 909-234-03five9 |
Re: Honda Civic VX 5 Wire conversion for sale
OP should say a conversion for 93-95 Civic VX since the '92 VX has no need to do a 5 wire conversion.. Also it would be a 49 state ECU, not 48 state ECU. As for the EGR control units, I thought the EGR system in the Civic VX is completely unchanged and that the only difference in the VXs was the o2 sensor and ECU..
Everything is Sold! Thanks.
Not sure on the EGR part, but the rest sounds correct. Thanks. |
