Re: Window Up or Down?
HC- good point.
I verified that the 94 Accord ac compressor will only run when the defrost is on or when the ac button is pushed, it doesn't run when the selector is on "vent" and "recirculate" without the ac button pushed. In fact, I feel the car shudder when driving at interstate speed as the compressor kicks on and off as the position of the ac button is changed. |
In my experience, Fords and GMs use the compressor with recirculate, and Toyotas don't.
I googled it. One person on a BMW forum said Fords do not do it (and BMWs do, which is why I found that forum as a result). The proposed purpose is to remove humidity that could build up inside.
Thanks but no thanks, if it gets humid I can turn on the A/C myself. Another proposed purpose is to exercise the A/C system and keep the compressor lubricated. That makes more sense to me. |
My dad once said older Chryslers used to run the compressors for 20 seconds each time the car was started to keep it lubricated.
I agree that manually cycling the compressor is the way to go. I can keep it cool enough, and the compressor seems to be engaged a lot less.
Call me a spoiled American if you will, but I <3 automatic climate systems (until they break).
windows down at any speed (A/C busted for 7 years now and too cheap to fix it)
I think myth busters did a bit on this one but I don't recall what they found with it. they used an explorer and ran an entire tank through at a closed course/race track. it was late and I fell asleep. really wish I would have caught the end of that episode. |
The new Ford Fiesta runs the AC in "stealth mode" in the defrost position. Both the defrost position and defrost-and-feet do this. The AC on/off light doesn't light up and you can't turn it off.
