10 Tips Could Save You $100 a Month at the Pump
OnStar data shows mileage of drivers in identical cars can vary by 75 percent 2011-05-26 DETROIT ? With Americans paying an average of $1 more per gallon of gasoline than a year ago, many drivers are looking for ways to improve their fuel economy during the Memorial Day weekend ? the unofficial start of the summer driving season. To demonstrate 10 common mistakes drivers make that hurt their fuel economy, Chevrolet recently drove two identical compact cars on a typical workday commute. The results show that sweating the small stuff could save drivers as much as $100 a month at the pump. For the drive, GM fuel-economy engineers Ann Wenzlick and Beth Nunning drove identical Chevrolet Cruze LTs, which the EPA estimates get 24 mpg city, and 36 mpg highway. For the route, they drove both cars for 20 minutes, including city and highway driving as well stopping for coffee. Wenzlick averaged 37 miles per gallon using efficient driving habits in a properly maintained Cruze. Driving inefficiently and ignoring common maintenance, Nunning managed only 21 miles per gallon. The difference means Nunning would get 250 fewer miles per tank of gas, while Wenzlick would save $100 a month ? or $1,200 a year ? assuming 15,000 miles and $4 a gallon for gas: Ann Wenzlick drive 37 mpg 575 mi per tank $1,621per year Beth Nunning drive 21 mpg 325 mi per tank $2,857 per year Savings 40 percent 250 mi per tank $1,236 per year ?Ann and Beth?s results support data from OnStar that shows the fuel economy of drivers in identical cars can vary by 75 percent,? said Roger Clark, manager of the GM Energy Center. ?With a well-maintained car, the best drivers get up to 25 percent more miles per gallon than average. When you combine a poorly maintained car with inefficient driving habits, the fuel economy of the worst drivers can be 50 percent below average. The fuel economy of every vehicle is greatly affected by how you drive, and how you care for your vehicle,? Clark said. ?Often, relatively small changes to your driving habits and vehicle maintenance can make the difference between being on the bottom, or the top, of the fuel-economy scale.? 5 Driving Tips to Save at the Pump Here are five things Ann Wenzlick did to drive more efficiently in her Cruze: 1. Get out of the drive-through lane. ?While Beth waited in the drive-thru with her car running, I shut off the engine and went inside for my morning coffee. Idling for 15 minutes burns through an average of a quarter of a gallon ? adding another $1 to the cost of your latte.? 2. Take it easy ?In the city, I accelerated smoothly while Beth demonstrated one of the most common mistakes we see on the road: Jumping on the gas at every light, only to hit the brakes as she caught up with the traffic ahead. Such aggressive driving isn?t going to get you home any faster, while driving smoothly can improve your mileage by 20 percent.? 3. Driving 70, not 80. ?On the highway, I drove 70, compared to Beth?s 80. Again, a 10-mph difference likely won?t add much time to your daily commute, but it will save you up to four miles per gallon on the highway.? 4. Use cruise control ?I tried to maintain a constant speed during our drive, while Beth?s fluctuated with traffic. Try using cruise control when possible, and maintaining a constant speed over time, which is much more efficient than speeding up and slowing down over and over again.? 5. Roll up the windows ?One of the most common questions we get is ?Is it better to drive with the A/C on, or off?? At slower speeds, turning off the air conditioning can save you a little, but I always roll up the windows on the highway. Beth was driving with her windows down, and the increased air pressure acted like a parachute trying to slow her down ? consuming much more energy than air conditioning ever will.? 5 Vehicle Mistakes That Hurt MPG: Here are things that contributed to Beth Nunning?s poor fuel economy: 1. Low tire pressure ?All four tires on my car were five pounds under their recommended air pressure. That?s not enough to change how the Cruze drives, but it does make the engine work much harder to turn the wheels. Check your tires at least once a month, as a tire that is 10 pounds under pressure can cut your fuel efficiency by more than 3 percent.? 2. Using roof ornaments ?To show support for my Detroit Tigers, I put up window flags on my Cruze for every home game. But, when the boys hit the road, the flags will come down. At highway speeds, up to a third of your fuel is used to overcome wind resistance, so even small changes to your vehicle?s aerodynamics will have a big impact in fuel economy. 3. Carrying extra junk in the trunk ?I had six bags of water-softener salt in the trunk I bought on sale at the hardware store. But, according to EPA estimates, every 100 pounds of weight can reduce fuel economy by 2 percent. While I saved at the checkout, that 240 pounds of salt added almost 5 percent to my fuel costs for the trip.? 4. Ignoring the ?check engine? light ?I called OnStar to run a remote diagnostics check on my Cruze, because the check engine light was on. Turns out the light was on because the gas cap was loose. But, more serious engine problems can cut your fuel economy by up to 40 percent.? 5. Not bundling errands ?An engine at operating temperature is up to 50 percent more efficient than a cold engine. So, when possible, it?s much better to run five errands in an afternoon, than running one errand every day of the week. About Chevrolet Founded in Detroit in 1911, Chevrolet celebrates its centennial as a global automotive brand with annual sales of about 4.25 million vehicles in more than 120 countries. Chevrolet provides consumers with fuel-efficient, safe and reliable vehicles that deliver high quality, expressive design, spirited performance and value. The Chevrolet portfolio includes iconic performance cars such as Corvette and Camaro; dependable, long-lasting pickups and SUVs such as Silverado and Suburban; and award-winning passenger cars and crossovers such as Spark, Cruze, Malibu, Equinox and Traverse. Chevrolet also offers ?gas-friendly to gas-free" solutions including Cruze Eco and Volt. Cruze Eco offers 42 mpg highway while Volt offers 35 miles of electric, gasoline-free driving and an additional 344 miles of extended range. Most new Chevrolet models offer OnStar safety, security and convenience technologies including OnStar Hands-Free Calling, Automatic Crash Response and Stolen Vehicle Slowdown. More information regarding Chevrolet models can be found at www.chevrolet.com. https://media.gm.com/content/media/us.../0526_fuelecon |
