-   -   DiamonLarry - is this true? (hydrogen-boost) (https://www.fuelly.com/forums/f8/diamonlarry-is-this-true-hydrogen-boost-1371.html)
Matt Timion 09-28-2005 02:15 PM
I saw your name today and I want to know if it's true or not.
https://www.hydrogen-boost.com/savings.html
Did you REALLY get 81.22mpg using this guy's hydrogen generator?
GasSavers_Diemaster 09-28-2005 03:13 PM
that sounds a little
that sounds a little doubtfull but then again hydrogen = hengiburg = flamable. i bet u could do the same running on propain. but then it's not 23 mpG it's 21 miles per Gallon of gas + propane used :P
diamondlarry 09-28-2005 03:25 PM
Hi Matt, You've probably
Hi Matt, You've probably seen this, but here is a link to the newsletter article. https://www.hydrogen-boost.com/May%202005.html The biggest reason I haven't mentioned this before is that I was never able to duplicate the results. I wasn't running his H2 generator at the time. I was however using many of his suggestions during the run. I was using heated fuel, Fran's driving techniques, Frank Norman's FFT, an EFIE from George Wiseman and if I remember right, some acetone. I'm working on writing up everything I'm doing and will send it to Matt as soon as I get it all together.
SVOboy 09-28-2005 06:03 PM
Wow
Just wow, that is truely amazing. And that's a whole lot stuff, I hope I can get to that point sometime. Pretty soon I'll be working on small things like reducing drag and whatnot, then I'll either redo my tires thing since it's all messed up cuz of the pump today, or work on acetone. Being fed up with tires I'll prolly go with acetone for now. How much do you think you used?
Flatland2D 09-28-2005 10:09 PM
Larry, I keep hearing about
Larry,
I keep hearing about these special driving techniques. If you at liberty to say, could you give us a brief explanation of what it's all about?
