Will a magnaflow catalytic converter fit?
Here is the link
https://cgi.ebay.com/ebaymotors/Magna...#ht_1476wt_804 I wanted to know if this will fit onto my civic vx because I recently found out that my exhaust manifold and cat is not from a vx, instead it's from a dx, lol! I would really appreciate if anyone could tell me the part number and a clear image of a cat for a 92-95 civic cx or vx cat and stock exhaust manifold, ty! |
Re: Will a magnaflow catalytic converter fit?
From looking at it, it seems like it would be the right size, but my VX has a 3 bolt flange on the bottom; then a 4 bolt flange at the top. The picture may not be accurate to the actual piece, though. Maybe you can contact the seller?
The 4 bolt is the side that bolts directly to the manifold. The bolts are not evenly spaced either. There are two wider ones towards the block. Does anyone else have any more info on this? B |
