For the "old school backyard mechanics"
Heard from a different forum that GM auto trans (particuarly the 4L60E or 700r4 thats in the s10 blazers) that requires the dextron fluid if you drain and flush the lines then put ford type F fluid in it will shift a bit harder but less slipping of the clutches. An older guy on the forum said hes been doing that for years with no problems over 90,000 miles. (180K on his truck so its well worn in)
Can anyone else on here give any insight to that? |
Re: For the "old school backyard mechanics"
i tried the procedure on a 4L60E once. it seemed to do the trick, however, i would not go for a complete flush and refill. all i did was drop the pan and add(top off) the type F. i would guess too much type F could do damage?
i dunno he even went as far as draining and refilling in 500 miles...
I know people that have replaced Dextron fluid with Type F. I would not mix the two, but a complete flush & fill should be no problem.
Nitpick: It's Dexron, not Dextron. There's no 't'.
I googled it. Of course there's the normal collection of "try this", "don't mess with this", "this improved it a little", "this made it a little worse", "this makes the sky rain money in your yard", and "this will eat your children"...but here's what I found that is of technical interest and seems plausible: https://www.ls1tech.com/forums/automa...60e-build.html Quote:
Conversely, I found this: Quote:
In my experience and in my opinion, the 4L60E is absolutely fine under these conditions: - Not exceeding stock power output by a whole lot (if so, use a 4L60E from a more powerful application; they aren't all the same inside). - Keep fluid maintained per schedule, using the recommended fluid. - Keep temperature down. I know that technically it needs to be up to operating temperature, but I can't argue with results: the lower, the better. Mine, which came with my 2002 GMC Sierra 1500, has 200,000 miles on it including some towing at my 14,000 pound GCWR in mountains. Recently I even ran it a short distance while it was so low on fluid that it was slipping severely...after fixing the leak (from an over-wrenched corroded cooler line) and topping it off it works fine. Of course, if you're using a significantly internally modified transmission then your fluid needs may differ. If it's too late and it's already failing then you haven't got much to lose, just the cost of the fluid... |
yea thast what ive heard it mainly for is the older worn out trans that slip or lazy shift, putting type F in it has returned it back to stock or better.
seems most people only get about 150-180K on thier s10 blazer trans before it crapps out, yea you get the oddballs that live forever or the ones that die at 80K im lookin for a nice 94 older s10 blazer and afraid i may get an auto again. if i can prevent the trans from puking id be happy. |
I wonder how different a S10 Blazer 4L60E is from the one in a full size pickup...it should last longer unless the vehicle is modified and/or abused.
I doubt you'll find one with a manual transmission, but they're always DIY...should be easier than my Buick was. |
well they came factory but generally the people who know how to shift manual and voulenteered to buy one keep them forever untill thier about ready to fall apart.
there are several variations of the 4l60E, the fullsize trucks got a beefier internals and different clutch plates (bigger i belive) to handle the V8 and towing capabilities. the blazer got smaller /cheaper internals so they just dont hold up... |
