Coil over spark plugs
With these systems, when replacing the spark plugs, is there anything else that should be replaced?
Re: Coil over spark plugs
the coils on those systems are expensive so I would probably say to just replace the plugs and see how it goes.
I had a dodge with that setup and it had 8 coils in it. I would hate to have to replace all of those. |
I don't think the coils them selves need it, but I came across replacement boots while looking for the plugs.
replacement boots?
if they were just a few bucks I would throw them in just because. if they were a little steeper than you want to go, I would check the old ones to see if they were dry or cracked and go from there. |
Yes, the boots are replaceable on most vehicles and ought to be changed like plug wires would. Just ask at your local parts store.
