Winter Blend Arrival
So it's now getting toward the end of September, which means it will be cold for some of us soon and the rest of us in a few more weeks. When does this winter blend of fuel arrive, and how much of a significant drop in FE can I expect? I'm running 47 mpg right now, so should I look for 10-20 percent drop? Or worse???? :eek:
Re: Winter Blend Arrival
I believe its the first day in October (or is it November?) through the first day in April. I tried looking it up online and could not find specific dates.
I thought it was different for different areas. I didn't think florida (or at least the southern part of it) got the winter blend at all.
remember that it isn't just the gas that hits your FE in the winter. usually the driving conditions are different (snow, ice, and what not) and also the warm up times are significantly greater. also if you are one that warms up his car in the morning, that pings it as well. |
I'd say the cold weather is the biggest factor, higher starting idle over a longer period of time. More fuel used with thicker oil relative to ambiet temps, etc. |
I am just sharing what I have read/been told.
summer blend yields you better efficiency. winter blend yields you much better cold start performance I have never tried it but I have heard that you would have a time starting an engine in the winter using the summer blend gas. that may only be true on older non-FI engine....it may not be true at all. realize that there is a lot of heresay about this but even I will say that there is usually one tank during the spring where my FE jumps around 3-5MPG and stays there pretty much through the summer. |
So nobody really knows? You guys are a lot of help!!!! :D
