-   General Maintenance and Repair (http://www.fuelly.com/forums/f10/)
-   -   Civic VX 5 wire O2 sensor from HX - will this work? (http://www.fuelly.com/forums/f10/civic-vx-5-wire-o2-sensor-from-hx-will-this-work-14079.html)
sknlim 02-07-2012 09:46 AM
I'm going to do the CA to FED swap and was wondering if this O2 sensor off the Civic HX would work?
L1H1:LZA12-H2 NTK
sknlim 02-09-2012 09:33 PM
Re: Civic VX 5 wire O2 sensor from HX - will this work?
I just finish wiring the car and everything works great. No CE and lean burn works.
The only reason i asked was because the O2 sensor had a blue wire.
add|ct 02-09-2012 10:44 PM
Oh, sorry no one answered your question before you tried. Basically, the 02/LAF sensors from '92-'00 VX/HX models are compatible if they are 5-wire. The NGK/NTK 24300, for instance, can be used as the replacement on both.
