Mothballs / Napthalene / WD40
So, crushing up some mothballs into your tank, 5 per 1 gallon I think, might be for only carbed, but I've seen FI to, heard 2-3 mpg on a mazda protege. 99% napthalene type you need
And napthalene is something refined when gas is, so it's not like sugar, should be a good thing to test the heck out. |
Quote:You can also add 1
Actually it seems like
Actually it seems like everyone who uses mothballs varies their amounts a whole lot, something to test for me after acetone I guess, though I wanna do tires and spark plugs and chipping sometime...
"You purchase white
Quote:"Can mothballs
1950's Racer Tech
My Dad told me how they used to put mothballs in the tank to win drag races circa 1955. Full circle, cool. Unfortunately, common-rail diesels and carb'd cars would benefit the most, instead of FI.
RH77 |
Quite truthe, still worth a
Quite truthe, still worth a try, I say. And if it gives me more power and no mpg then I won't complain about that either.
Moth balls and WD40
This guy uses moth balls and WD40
https://www.georgenitta.com/mothballs/mothballs.htm |
The only thing else I would
The only thing else I would suggest when using mothballs is that they be crushed to a very fine powder and mixed in some gas before adding to the tank. I would be concerned about the whole mothballs turning into a large gooey mass as they were dissolving. This could perhaps also reduce the number of mothballs needed. I have a box of mothballs but I want to thoroughly test my Ethos before I start on anything else.
I find it hilarious that
I find it hilarious that people are adding expensive chemicals to "improve fuel economy". That $2.49, 16 oz. can of WD 40 costs the same as a gallon of gasoline to gain perhaps 1% more miles to your tankfull. It would ge better to spend the same $2.49 on a gallon of gas, and get 10% more miles per tankfull!
The same thing applies to other additives like acetone or napthalene, all of which ultimately came from an oil well in Saudi Arabia. |
