Cross-Ventilated Rotors. Worth It?
Are Cross-Ventilated Rotors worth the cost?
I'm about due for pads and because there is a slight vibration from a hot spot on one of the rotors I may replace the rotors rather than turn them. I often carry large payloads but, more importantly my stopping involves long periods of gentle braking, empty or loaded, rather than hard braking. |
Re: Cross-Ventilated Rotors. Worth It?
Have you had problems with brake fade?
I would think that anything that will lower braking temperatures would be worthwhile, especially if you spend as much time driving as you do. |
Never faded. Mechanic said the reason for the vibration was that I didn't break-in the last set of pads.
Do you have a link to the rotors you were thinking of purchasing? |
