Fully Rebuilt VX Swap
Debating on selling my VX swap.
The long block is FULLY rebuilt. ALL new gaskets, bearings, and rings. Everything was mic'ed and set to factory spec. Hear is the rundown: New Oil Pump New Water Pump New Headgasket New Intake and Exh Manifold Gaskets New headbolts New Valve Stem Seals New Goodyear Gatorback Timing Belt New Oil Pan Gasket EVERY GASKET has been replaced. Oil Pan was stripped, cleaned, repainted. Block, Head, and Intake Manifold were Hot Tanked and Cleaned. The Long Block will be fully put back together today. Waiting on the Intake Manifold to come from the Machine shop now. Swap will include all of the following: EGR Box VX Manifold NTK 5 Wire Fed P07 ECU Cali P07 ECU Complete VX Longblock (Flywheel to Crank pulley/Valve Cover to Oil Pan/Exh Mani to Intake Mani) VX Transmission Stock Pressure Plate 4 Puck Clutch VX Wire Harness (Uncut and meticulously cleaned by me.) I fully rebuilt the motor and cleaned everything up to do a unique swap in my Civic 4 Door, however, I have decided to go another route with my swap. Price is $1550 obo and willing to ship at buyers expense. |
Re: Fully Rebuilt VX Swap
1050obo!
Where are you located?
North Carolina. I can ship though.
