civic vx shift not working?
Hello,
Just got a 1995 Honda civic vx. the shift light is not coming on when going throught the gears. I know the light bulb works, when I turn the key on the light does come on. The prev owner did replace the o2 sensor and the distributor. The o2 sensor was replace a year ago. the light was working until he replaced the distributor ( also the check engine light came on) pulled the code. tracked it down to a crank sensor wire that was pushed out of the plug going to the distributor. I reset the ecu by pulling the back up fuse under the hood. shift light still not coming on. Any ideas? Thanks
