92 Honda VX $4200
FOR SALE: 1992 Honda Civic VX! Best MPG at 58! The car has 213k, does not burn oil and has great compression. I have done a lot of work to this car. Besides all the repair work I also installed a 6 point roll cage and installed a cable to the ECU to watch the O2 sensor or lean mode. I also modified the original interior to fit around the cage. Below is a list of everything I did to the car and what it still needs. With all the repairs I used only quality parts, most from Japan.
The car is located in northeastern Ohio. The reason for the sale is that I have moved to Montana and opened my own repair shop. I just don't have the time to make it back to Ohio and bring it back here. I hate to see it go, it took me months to come to the conclusion to sale. Mods: 6 Point Roll Cage with removable center bar with original interior to fit around the cage O2 sensor cable from ECU to watch voltage Repairs Rebuilt transmission with all Japanese bearings Timing belt, water pump, cam and crank seal. ( Asian water pump, Contec timing belt ) Value cover gasket with value adjustment ( Fel-Pro ) O2 sensor ( NTK ) Rust repaired and heavy undercoat on important spots Fresh coolant with distilled water New plugs and wires ( Denso ) New clutch Fresh Synthetic oil ( Mobil 1 ) Bad: V-tec solenoid leaks oil Comes with an extra low mileage engine. Asking $4200 obo. Here is a link to some pics HondaVX Photos by Subaruguy | Photobucket |
