A/C Question
The A/C is deader than a doornail.
Here's the leak: https://lh6.googleusercontent.com/-K...o/DSC07225.JPG Could it be as simple as an 'O' ring: https://lh6.googleusercontent.com/-D...o/DSC07228.JPG |
I'd say it looks like you got a leak there. You can buy an assorted pack of O rings for a/c systems at most auto parts stores for about $6. Make sure you buy the green ones. The black ones don't hold up as well. If you can get a hold of it, Loctite makes a special form of Loctite to seal refrigeration systems. I usually put a thin film on the mating surfaces as an extra assurance that its sealed, and I'm good.
Depending on the age of the vehicle, you may want to consider taking all the freon fittings apart and replacing the O rings, and sealing it back up. Make sure you hook it to a vacuum pump and vacuum it out to boil off any water left in the system before you refill it with Freon. EDIT: Be sure to clean the oil residue off that fitting with some brake or carb cleaner so you can tell if it starts to leak again in the future. |
