'93 Civic VX Smog woes..
Two years ago, I bought a '93 Civic VX. It has been a great little car. Until I had to get it smogged.
The car passed emissions (barely), but smog tech found a second cat on the underbody of the car and failed it for a modified exhaust system. I went to install a new cat only to find that the normal bolt on doesn't fit in the exhaust manifold and my only option was to buy a $700. The shop tech offered to swap the exhaust manifold but he was told by the supplier that doing that would also violate the modified exhaust rules. So I had the second cat removed and did a pretest, now it fails on all counts. Worse yet, the pre-tester says I have a non-standard JDM engine and I have to make an appointment with the referee. I made sure before I bought the car that the engine had VTEC-E stamped on the top of it, and I assumed (apparently incorrectly) that that meant it had the correct VX engine. Now I read on the forums that it's common to hollow out the engine cat and put on the underbody cat, so I really might not have a functioning cat at all. A couple of questions: 1. How can I confirm whether or not my engine is the right engine? I know they have model numbers, but where are they stamped? 2. What the heck can I do to get this car to pass smog? |
Smog numbers, in case it's relevant:
5/21/2013 (both cats): 15mph: RPM: 2575 %CO2: 14.4 %O2: .6 HC: Max 68 Meas 67 CO Max .59 Meas .39 NO Max 731 Meas 243 25mph RPM: 2304 %CO2: 14.8 %O2: .3 HC: Max 44 Meas 35 CO Max.41 Meas .03 NO Max 798 Meas 569 7/24/2013 (with underbody cat removed): 15mph: RPM: 2607 %CO2: 13.8 %O2: .8 HC: Max 68 Meas 67 CO Max .59 Meas .87 NO Max 731 Meas 659 25mph RPM: 2298 %CO2: 13.8 %O2: .8 HC: Max 44 Meas 78 CO Max.41 Meas 1.00 NO Max 798 Meas 862 |
