Squeaky wheel, bearing preload
I have squeaky front wheels. Sounds like a hamster wheel. No change during braking. I jacked it and the classic wheel bearing rock test had slight play. I tightened my drivers side wheel bearing spindle nut and that squeak went away. I'll do the same on the passenger side.
The 1980 Buick Chassis Service Manual published by GM says this about adjusting it: Quote:
I used a scale-type torque wrench to try to gauge just how tight it was. The one I have is craptastic. I can at least tell you it was somewhere between 5 and 20 ft-lb. Am I gonna burn up my wheel bearing? The wheel does not fail the rock test anymore, and spins freely. |
Just came across this thread again.
I found the problem. It was my wheelcovers. https://www.fuelly.com/attachments/fo...fe577eadb4.png |
I have beauty bands on my yaris and they make noise too. irritating but aesthetically pleasing. I just deal with the noise.
Isn't it embarrassing though?
You might be able to silence it with some silicone caulk. I took my wheelcovers off, planning to caulk them, then got lazy and drove around a while without them until I scored a set of '57 Buick Roadmaster wheelcovers that look surprisingly nice on my car, but then one of those keeps flying off so I'm driving around with 3 installed and one stored until I do something about that....at this point it's only a month until I'll be putting on my winter tires which are on aluminum wheels anyway... |
mine is more of a clicking sound. I just go with it. generally I get up to speed pretty fast with the yaris and it doesn't do it once the centrifical force gets high enough.
I thought about just getting some wheels in the style that I have now (black with a polished lip) though I am cheap... |
