Shutdown/Startup vs continuous idle fuel consumption
Assume I am driving a gasoline-powered fuel-injected 4-cylinder economy car.
Say I am in line at the drive-up window of a bank. There is a car ahead of me at the window, engaged in a long transaction. Will I save gas by shutting off my engine for a few minutes, then starting it again to pull up to the window? Put another way: How much gas is used to start a fuel-injected engine, and roughly how many minutes of idle does that fuel represent? |
A good basic rule of thumb for a gasoline engine is if you're going to be stopped more than 30 seconds, shut the engine off. 60 seconds for a diesel.
Thanks, this helps me as well. I have an automatic and I've been trying to figure this out.
Off every time i'd say, forget about timing it! Every car has start/stop built in now, and from experience, it shut's the engine off after about 7 seconds of idling in normal conditions, and starts again as soon as the clutch is pressed.
Perhaps it will be selectable with an ECO mode or some such, but the default will likely be start/stop off with AC on. |
