Should I change.......????
I'd like to make a thread where we ask what parts we should change or keep them. I'll go first.
My car is almost at 63,000miles. The spark plug wires and and distributor cap and rotor haven't ever been changed. I haven't ever replaced the distributor cap, rotor and the spark plug wires. They are from the factory. I also checked maintenance records and they were never changed. Money is not a problem. I plan to buy NGK spark plug wires which are a little better than the crap that is on now. The rotor and the distributor cap will be bought from the dealer because it's the best quality there. The rotor will most likely be changed by the dealer since I stripped the bolt that holds it. I can change the wires and distributor cap myself. Should I change them now or wait till 75k which will be time to change the spark plugs??? |
You can usually tell
You can usually tell original plug wires because they will have the year the vehicle was made printed on them. 63K, if it were me, I'd go ahead and change it all instead of waiting for the 75K mark.
One good thing most people don't realize is that Advance Auto [and I think Auto Zone as well] offers a 1 or 2 year replacement warranty on NGK spark plugs [maybe other brands too]. After you purchase your first set, be sure to take them up and get new ones before the warranty period ends! |
I didn't know about the
I didn't know about the plugs. Count me in.
I would agree that some stuff needs to be replaced, even early. Preventative maintenance is never a bad thing. The first thing I did when i got my car was replace my o2 sensor. If you can afford it, you might as well replace that too :) |
PCV Valve and Catch Can + ...
For future engine cleanliness I'd recommend changing the the PCV valve and install an oil catch setup to keep things cleaner in the intake plenum and injectors down the road.
Another thought would be to install a hotter thermostat. I agree on the 02 sensor, but I haven't heeded my own advice on that one yet. Pull off of the car anything uselessly weighted, like a intake air silencer. If new tires are in your future plans look to low-rolling resistance ones... RH77 |
Re: PCV Valve and Catch Can + ...
Add to that the reviews of LRR tires on www.tirerack.com. hardly anyone seems to like them. Is there a good, affordable, LRR tire out there? |
RH77 |
The PVC was replaced and the
The PVC was replaced and the fuel filter was replaced. The tranny fluid was replaced. The valve cover gasket was replaced. The windows switch was replaced. The CV boot was replaced. Alignment was done.
Just the wires, cap, and rotor never been replaced. Otherwise everything else in the list HAD to be replaced because it didn't work or made the car worse. New tires were installed 5k ago. What do you think about these spark plug wires??? They are made just for my car..., Should I get these? https://www.ngk.com/more_info.asp?AAIA=1356757&pid=3057 |
Re: The PVC was replaced and the
Ok, I ordered those. When I
Ok, I ordered those. When I receive them I'll get the rotor installed and install the cap and then put them on.
I went yesterday for a drive and proved my own theory. My car gets 30's on the freeway. To bad I always can't drive on the freeway. I don't know where in the 30's though. I predict low 30's mpg. |
Re: Ok, I ordered those. When I
okay, bad idea. |
