-   -   OD for big block fords? (https://www.fuelly.com/forums/f11/od-for-big-block-fords-14947.html)
IIbulletcatcher 01-23-2014 06:20 PM
I have a 77 Mercury Cougar. It has a 351m, which as far as powerplants go, is a sad puppy. It's an engine that gets small block power with big block fuel economy, the worst of both worlds.
I don't want to pull the engine since it works fine, but the 351's status as a big block means that my choices are limited when it comes to alternative transmissions. Problem is, I don't know what my choices are. I've heard something about a 5 speed for trucks that might work, and on the $$$ side I've heard about people getting adapter plates and pulling a AOD from a crown vic, but past that, nothing. I want the most driveable transmission for the buck, and I need ideas about the application and the cost.
Any help, guys?
Jay2TheRescue 01-23-2014 07:05 PM
That would be the crown vic tranny with overdrive then.
hypermarquis 01-24-2014 12:45 AM
Here is an article about "Ford AOD Overdrive Transmission-
Create a conservative Cougar or a miserly Mustang" from Hemmings.
I hope it is what your looking for.
https://www.hemmings.com/mus/stories/..._feature5.html
IIbulletcatcher 01-24-2014 03:35 PM
Thanks much, though it doesn't really help in terms of finding out what other tranny's are out there... it assumes a small block bell housing, which my engine doesn't have.
kc8swy 04-13-2014 01:54 PM
You need a GearVendors Over/under drive unit.
bkxmnr 07-17-2014 04:34 AM
bulletcatcher, I believe the trans you want is the E4OD. They should be quite plentiful. I don't know what type of trans controller you will need. Baumann Engineering may have a solution. I could be completely wrong as I'm pulling all of this from the deep dark recesses of my brain.
Wyowanderer 07-18-2014 09:45 AM
Call up a local auto wrecking yard and ask them to tell what interchanges from their Hollander manual: they're usually quite helpful to tell you. If the first 'yard isn't helpful, call another, and another until you find one that is.
bkxmnr 07-19-2014 09:33 AM
Another thought - you'll likely need shorter gears in the rear end. The mechanical advantage should perk the car up a bit.
richmond2000 07-19-2014 04:54 PM
try an 80's F250/350 tranny from a 460pick up/van as the 350M/400 use the "big block" bell housing shared with the 460 engine
