Detailed Fuel Consumption Data
I have an idea for fuel consumption measures at idle.
Why not scangauge and OEM "Trip Computer" manufacturers seperate the MPG data with and without idling ? Lets say the trip computer has a "more detailed" function that also shows the MPG in various speeds like: Overall MPG = 26 Detailed: MPG without "0" speed = 33 MPG between 0-10 mph = 9 %5 of distance traveled MPG Between 10-20 mph = 14 %17 of distance MPG between 30-40 mph = 28 %23 of distance MPG between 40-50 mph = 49 %55 of distance MPG between 50-60 mph = (NA) %0 of distance etc.. or MPG at 1st gear: 6 %4 of distance traveled MPG at 2nd gear: 12 %12 of distance MPG at 3rd gear: 34 %27 of distance MPG at 4th gear: 47 %57 of distance etc.. Do you know aftermarket manufacturers or OEM trip computers that give this kind of detailed fuel consumption datas ? If not: i think it can be done by having an OBD2 scanner interface between a PDA or Notebook computer and writing the appropriate application for it. |
This would be very helpful,
This would be very helpful, but unfortunately I do not think too many people care about detailed information such as this. I feel it would probably have to be a custom application made by an enthusiast.
Unfortunely this type of thing is only easily doable on obd2 cars, which a lot of us do not have. Actually, maybe SVOBoy can help with datalogging on obd1 ECUs and we can figure out a way to monitor gas mileage using datalogging. |
Re: This would be very helpful,
Took me forever to respond, but here's the deal on this. ECU does its junk by time the injectors are open, so you could figure out the fuel consumption, but you'd have to have the car tuned perfectly and run in open loop (no 02 input) so that it wouldn't get hit with a lot of correction factors. This would negate things like a warm air intake, because it would assume a certain temperature, though if you normalized the intake temperature you could figure this out so you still got the benefit easily enough. Also, at this point, you'd have to whip up your own program (I could do it with an *** load of effort, :( ), and run the crap always on a laptop. I dunno about making a display that's run standalone usb stuff, hmm. |
The Lincoln Town Cars that I
The Lincoln Town Cars that I drive are from 00 to 05, and they have a display to show an approximate MPG at a given time. The displayed MPG does not change when the car is stopped, although it does when the car is moving slowly. Would it be possible to piggyback in an ECU from a newer car to read the data from an older car?
Re: The Lincoln Town Cars that I
Quote:that's probably the
for non-obd2 people... do
for non-obd2 people... do you actually need to see mpg calculations?
e.g. is there a tool that would let you monitor efficiency by logging MAF or MAP readings? both would decrease as you increased efficiency, wouldn't they? (for a given speed, I mean.) you'd just need an "average" function to make it useful. (i've found that most of the instantaneous data from the scangauge is pretty much useless because it changes rapidly and constantly). |
The vacuum gauges suck, so
The vacuum gauges suck, so much so that it makes it difficult to figure out what's going on. Scanguage has the trip stuff, so you can make the same trip and compare, but a vacuum gauge and other low-tech junk won't do it.
i agree - a vacuum gauge
i agree - a vacuum gauge won't be that useful. but i was thinking more along the lines of digital tools that could do datalogging.
i'm not familiar with pre-obd2. but i just assumed (maybe wrongly) that you could get at least *some* of the electronically monitored info that you can get out of the newer cars. |
Re: i agree - a vacuum gauge
There is a version of the zemco fuel saver that can be used on obd0 and obd1 fuel injected cars but it requires a second sensor that I'm certain no longer exists. obd0 and obd1 carbed cars can use the zemco fuel saver to calculate mpg with no problem. |
