Underdrive Pullies
This seems to be a very common thing for tuners/ race oriented people to do, but I really haven't heard of anyone metioning it for fuel economy. Of couse they cost $100 or more and gains must be minimal. You would have to drive 1,000,000 miles to get your money back.
i can get one for my car for
i can get one for my car for about $50 US. it's on my list for testing out next spring when my tools warm up again.
i'd be very surprised if it made any more than a 1 or 2 percent difference. still worth trying though. hmmm... for the amount i drive, a 2% improvement will save me about 12 L a year, or $9 CDN at 75 cents/L. i'd have to drive about 60,000 km (37k miles) to break even on a $50 expense. |
Here is another
Here is another gadget:
https://www.gassavers.org/forum_topic/alterpower_shutting_off_alternator.html |
interesting - thanks.
Re: Underdrive Pullies
Less drag on engine equals more power and better economy (even if the amounts are small to minute) Less load on the engine could help in longevity of the engine. Less load could make quiter engine at all speeds. (hey it's the little things that count sometimes :)) |
Quote:(hey it's the little
update (propaganda ) on the
update (propaganda :) ) on the underdrive question...
found this on the teamswift site, from one of the 2 guys who makes and sells them. completely unsubstantiated, likely not tested under controlled conditions, and i'm still skeptical because it seems excessive. but here you go: Quote:
50 bucks eh, for 8% that's
50 bucks eh, for 8% that's worth the risk, I will go to look about them for my car and report back!
Re: 50 bucks eh, for 8% that's
i still think it's going to be much lower than 8%.
ooo! surfing around, just found this... some serious underdrive debunking: Quote:
water pumps... the quote above is talking about racing engines (v8's i gather). obviously the size of the gains to be had depend on engine size. let's do some rough math for my car: on the teamswift site, one guy replaced his water pump with an electric one that is rated at 1/2 hp, and is stronger than stock. so let's say the stock one costs 1/3 hp. underdriving it by 25% would save me 1/12th of one hp. let's be generous and round it to 1/10th to accound for reduced aero drag on the alt. 1/10th of 1 hp = 75 watts. that won't even power my headlights. yes, it will save fuel, but looks like the savings will be negligible. continuing further down my very rough calculation road, another figure you see quoted often is road horsepower at highway speed. i.e. i've read several estimates that it takes a modern car between 10-15 hp to cruise at highway speeds on level ground. assume my car gets 50 mpg (US) at 60 mph and needs 12 hp. if i save 0.1 hp with the underdrive calculations, my highway load drops by 0.83% (0.1 / 12 hp). if the fuel consumption drop is linear, i have just gained 0.42 MPG (50 mpg * 0.83). suddenly the investment "risk" doesn't look so good (from a strictly fuel saving perspective)... |
Someone tested a saturn
Someone tested a saturn stock and a saturn with no crank pully at all and said they only gained 3 hp. They implied that underdrive pullies would provide little if any hp gains.
https://www.teamscr.com/pulleys.htm I belive this test is totally wrong because the crank pully acts as a blancer for the engine. and a engine with no crank pully would be out of balance. |
