volume correction of gas sales
interesting page about volume correction in fuel sales: Buying Gasoline in Arizona
covers things like
why? because... Quote:
(though you could argue it's harder to extract that energy as efficiently at lower temperatures...) for some reason my brain is slightly resistant to absorbing this concept. e.g. how does volume correction, or lack of it, affect MPG calculations? hmmm?? think about that. for one thing, it means if you calculate your MPG on the back of your fuel purchase receipts based on volume reported, it's going to be a bit different than "real" MPG calculated electronically by your car (or scangauge). how it compares depends on the temperature of the fuel and whether it's volume corrected or not. for another thing, it means that according to my fuel receipt, at 0 degrees C i can put 40.75L of gas into my 40L tank (not talking about filling the neck either) |
After reading this, the one
After reading this, the one thing I don't understand is why they complain about rounding up .5, I was tought since whenever to always round up .5 and have never been told otherwise.
Gasoline energy
Density isn't the only thing that changes the amount of energy in gasoline. The types of chemicals making up gasoline has a bigger effect than density:
Some gasolines ingredients are "aliphatic", some are "olefinic", and some are "aromatic". Each of these types produces different amounts of energy when burned, and you never know which ones you're getting in a gallon. Then there are the "oxygenates" (methanol, ethanol or methyl tert-butyl ether). They have less energy than straight gas, especially methanol. |
true, sludgy, but let's be
true, sludgy, but let's be careful not to use the fact that chemistry is also important to dismiss the importance of density changes. (not saying that you were; just raising the point.)
it's clearly significant enough that entire countries and some states have legislated to try to compensate for it. consider this: until i read that page, i never understood the common fuel saving tip that "it's better to buy gas in the morning". to canadians (and hawaiians), it's irellevant when fuel is bought (assuming steady price of course) because it's volume corrected to account for changes in temp. i didn't know that most U.S. states (is hawaii actually the only one?) don't volume correct fuel sales. also consider this: all else being equal (which clearly is rarely the case), if you're doing mpg calculations based on non-corrected fuel purchases, you'll go less far on a gallon of gas purchased warm than on a gallon pumped in cool temps. it alters winter vs summer mpg calculations. |
Quote:consider this: until i
nope, didn't see that
nope, didn't see that thread.
you might as well post the link to it (no point in a bunch of "dead end streets" in the forum - where they overlap we should try to make it more of an interconnected neighbourhood concept, for people who "move in" later, like me :) ) it also raises the question: is it really fair or correct to compare the MPG of a flex-fuel vehicle to a gasoline powered vehicle if the fuels have different energy densities? or the mpg of diesels to gasoline, for that matter? |
<a href=https://www.gassavers.org/forum_topic/time_of_day_to_fill_up.html target=_blank>https://www.gassavers.org/forum_topic/time_of_day_to_fill_up.html</a>
There you go, sir. |
yes i can see how that tip
yes i can see how that tip got started (from the days of above-ground tanks) and agree it's likely that underground tanks have much more temperature stability.
that said, underground tanks are often installed directly beneath asphalt paving as well. we know what the thermal rate of expansion is, so the experiment would be to simply measure it. bring along a digital thermometer and a small container to the gas station one day. of course this experiment won't benefit me at all... |
