Odometer Number incorrect [Logged]
The odometer reading now is incorrect when using the "show all fill ups" link after the latest upgrade last night.
henrie8th,
From here: https://www.fuelly.com/car/toyota/cam...8th/260269/log Are you missing a fuel-up? What should the Odometer be? |
I just installed the new version, and the "Odometer / Trip" field shows zero on all my fill-ups. I guess I could manually enter the trip number manually from my paper receipts (all 59 of them), but that would be a major pain. It sounds like there was a problem with the data migration. Wasn't this tested, on a test server before going into production? I work in IT, and we'd never let stuff like this in our environment.
Also, quite awhile back I asked about an enhancement, to be able to set a default city/highway ratio (mine would be 90% city) in Settings, but I see that didn't make it into this release. It used to be 50/50, now it's "City driving % 0".
And just to clarify, it's only on the on the iOS app where the trips show zero. It's correct on the Web site.
TXEditionLB4x2,
Do you track via trip distance instead of odometer? If so, this is a display issue in the app that will be fixed in an update we are submitting to Apple this evening. The data isn't missing or lost, it's just not displaying via the app correctly. Also city/hwy defaults to 50% right now... where were you seeing it default to 0%? In the GasTracker app or on Fuelly.com? |
Hi All,
I am getting the same issue but on the Website with both vehicle Stats. All my odo reading are out for the Subaru the last one being over by about 80000km. (Car 129000km - Website 209000km). I have 149 entries waht is the process to rectify this? Regards, James |
Yes, I use trip rather than odometer. And as far as city/highway goes, I was asking for the ability to set a default city/highway slider value in Preferences, so that I don't to move it from 50/50 every time. I had posted this awhile back as an enhancement request. I just looked at the iOS app and the Website, and on both, the slider is all the way over to the left (city driving % at 0%) on all fillups where I haven't set one manually. |
In checking back on all my hand written fill ups, the km per tank is correct but all of the actual odometer numbers are now larger by a factor of 1.609 (conversion from miles to km). All of my data is entered in km and litres. The odometer only shows up when I use the "show all" routine.
For a reference, my last fill up on 30 May used 52.57 litres and the odometer reading was 21849 km. The report shows odometer of 35235 km! It seems like everything else is still working fine. Great site, appreciate all your work. |
