Problem with "Chart all Fuel-ups graph display
Since the upgrade I noticed a problem with "Chart all fuel-ups" link.
No MPG is displayed when you hover your mouse over a fill up unless you go to the very first fill up. Only then it will display your most recent fill up, when you select your first fill up. This problem started today after the upgrade announcement. I also see the amount of gallons entered does not change when you go back to edit it. It will display correctly on my dashboard but not when you go to re-edit the fill up. |
in the yearly charts it counts the notes as fill-ups now.
Fuelchart not supported?
It looks like this link doesn't work after the update:
https://www.fuelly.com/driver/cobrapa...phev/fuelchart Is fuelchart still supported? Thanks! |
Take a look at the chart now. The data points should display.
The old fuelchart links are still not working. Is the format changing and is that the new format for links? There is now a random number in that link (link at a different level.) Should that be used instead?
Thanks in advance |
Yes, you should use the new link.
