ISO date Format
The recent change has stuffed up the date format.
Although my profile still says that I am in Australia, dates are being displayed in the unreadable form of MM/DD/YYYY. It's ugly and unpleasant, if you had simply switched everything to ISO format (YYYY-MM-DD), at least it would be sensible. |
Agreed! It's retarded as it is.
Kindly add my vote for the ISO 8601 international date format.
Could you please list all of the places that you are seeing the incorrect date format and your country (if not Australia, as has been noted above).
When I switch to Australia, I see the wrong date for the fuelup date when I am on the add a fuelup page. This one I will fix. I do see the DD / MM / YY format in other places though. That is the date format that appears to be correct for your countries. Nothing was done intentionally to give you the wrong date format as I strive to attach the proper date format to your selected country. |
That said, is it possible to offer a user-selectable option to display time in ISO format? I use it extensively in many other contexts as it makes the most sense. |
ISO date format is now in use. Thank you, freddie!
