CSV export column names mismatched
As the title says.
The CSV export I just downloaded has the following column names in this order: "car_name, model, l/100km, odometer, km, litres, price, city_percentage, fuelup_date, date_added, tags, notes, missed_fuelup, partial_fuelup, latitude, longitude" The data following is clearly mismatched: the first two columns, "car_name" and "model", appear correct, but the following ones are clearly misplaced and it is not entirely clear by a quick look which goes where. Regards, Dimitri |
Hi Dmitri,
I am not seeing a problem with the exported file. Here is an example of the first three lines of your exported file, can you point out the problem? The l/100km is 0 because of your partial fuelups. The export appears to match your fuelup log. Code:
car_name, model, l/100km, odometer, km, litres, price, city_percentage, fuelup_date, date_added, tags, notes, missed_fuelup, partial_fuelup, latitude, longitude |
Now I see it from your post - the file I get has comma instead of a dot as a decimal separator and the fractional values are not in quotes, which is causing the whole problem. Is this a setting I can change?
Oh, the comma as a decimal separator, I see the issue clearly now. I will work on fixing it today.
Give it a try now. The decimal separator will now always be a dot.
I checked it out, the problem is solved now, thanks.
