New Mileage nut, Long-Time efficiency seeker.
Actually, I've sought mileage for a long time too, but
it took a back seat to performance. I have been a major player in the V6 Mustang modifying arena -see SIX OFFENDER in the February issue of Muscle Mustangs and Fast Fords- but now I am hotly in pursuit of maximum efficiency and approaching it with greater T.E. in mind. If we could get gas engines up near diesel eff. levels then power would be easy to come by. I have a couple of engine ideas I'm working on, one is the "Optimized Otto Cycle" engine https://www.eng-tips.com/viewthread.cfm?qid=141129&page=1 and another is a top-secret exhaust heat reclaimer that could boost any diesel or gas emgine's efficiency quite substantially, to the point where one could conceivably start retaining coolant losses using higher thermostat settings and channeling most waste heat to the exhaust system and through the reclaimer for yet higher gains. Still in the planning stages. Perhaps FORD will buy it and save the company :D I will pursue a patent on this if testing shows a good increase in T.E. Back to the car-du-jour, '89 Tracer, the prior owners claimed 38 MPG (best I presume) and I have gotten 42.8 once and backed it up with a 42.6 and several tanks over 40 MPG. So far I have used clean plugs, timing advance, new tires (+1 sizing) 40 PSI (Diamond Larry, is 55 PSI safe???) and acetone. The acetone on very similar runs (70 MPH avg) showed a 25% gain on a tank, only change made except I was driving on a much rougher and hilly, curvy road for the higher MPG run. I'd like to compare it on the same road and I will get the chance soon. I hope to use many more tactics like fixing my fuel leak and maybe some aero add-ons but I need good info on what works for aerodynamic improvements. I can probably make most anything, I have good fab skills and resources. Glad to be here and hope for great MPG for all! Sincerely, Robert Greene Racing (RGR) |
Quote:new tires (+1 sizing)
55psi???
Is that how you are getting the mileage on that Saturn?? 55psi is going to really blow that tire to pieces if you ever get punchured. Keep an eye on the tire bead and sidewall cracking as they age.
I thought the 42psi I had in my new Scion xB was a little hard so I lowered them to 38.4 psi - yeah a weird number but I just lowered them with the digital gauge to the lowest of all four tire pressures after I started letting it out with a less accurate gauge then decided to split the difference of where I should be and where I was in pressure. Will need to check them soon to see how they are holding in the air at that pressure. Been almost 2 months. |
Re: 55psi???
i run at 38ish. any more than that and it's just too harsh. and i don't mean on me. all that pounding that would normally be absorbed by the tires is transmitted into the suspension - i cringe for the poor ball joints whenever i drive down a rough road, even at "just" 38 psi. |
I run 45 and I have my
I run 45 and I have my friend's 01 civic at like 52, never hard any trouble with that, but then again CRX and Civic have kick *** suspensions. I even managed to drift a 180 turn in my friend's civic at 40 mph with the tires that high. Surprised we didn't die.
hi pressure
Yeah you really feel the extra pressure with a new car - everything is stiff already and then add extra pressure . . . I remember the Geo when I went to 34 psi I could feel every crack in the road as I drove over them. One thing I don't miss from the Geo is the big bumps where I would bottom out the suspension and I am talking "paved" roads. Seems the xB has more travel and stiffer springs but still only 6.1 inches of ground clearance.
I have yet to bottom out
I have yet to bottom out mine, with 6 inches I believe. I'm dropping it to 4 soon, we'll see.
also it's more noticeable in
also it's more noticeable in the cold. i think i'll be able to tolerate more pressure in the summer. when everything's warm & supple, the suspension doesn't feel as brutal.
and despite being 8 yrs old, my car is essentially new - i just passed 5k kms/3k mi last week. so the suspension is much firmer than it has any right to be for its age. it should mellow some as i put on the miles. |
Are you serious? 400 miles a
Are you serious? 400 miles a year?
3k miles?
That is not even broken in yet! Heck I did more than 400 miles on my electric scooter last year!
