L/100km not calculated
The L/100km is not being calculated and showing as 0 for the last 4 entries. All data is entered correctly.
Your fuelups #11 and #12 are marked as partial fuelups so this is why you aren't seeing L/100km values.
See: https://www.fuelly.com/faq/6/partial-fuelups |
Same here with my last fuelup, the km/L is not being calculated and I already checked that it's not marked as a partial fuelup
You had your car set to miles tracking until before the latest fuelup. If you are going to switch from miles/km tracking to odometer tracking, you will need to edit each of the previous fuelups and enter the correct odometer setting for each fuelup. Perhaps you hit that switch by mistake? If so, set your car back to miles/km tracking and edit your latest fuelup to have the correct number of miles/km. |
I guess that was the problem. I already fix vehicle settings :whistling: best regards |
My last fuel-up #13 is not partial. But the L/100km is still not calculated/showing. And I am on odometer tracking. Please check and advice.
Thanks! |
Fuelups marked as partial and fuelups following a partial will not display MPG readings. |
Hi Freddie,
Thanks for the clarification. My mistake. I should have read the FAQ you posted earlier. Apologies. I have misunderstood the meaning of partial fuel-up. It is corrected and showing now. Thanks! |
