NO MPG after EDIT
When I edit my fill upafter a mistake the MPG's go away.
MPG didn't work today. Wutz up wid dat!!!???
Papajack: Your July 4 fillup is marked as a partial fill. When there's a partial fill, no immediate calculation is done for that fill, or the next. This data is still used in your overall lifetime vehicle average though. If this is an error, edit the fillup again, and uncheck partial fillup, and you will receive calculations for the past 2 tanks.
Actually, mark23487, take a look at your Log Book-
https://www.fuelly.com/car/ford/range...487/291706/log Your last fill up on the 25th shows an odometer of: 66,895. This is 60000 more than you had on the 24th! I'm guessing this was a typo. Simply edit and correct. |
Thanks!
for the reply |
