Gas Cubby Data Recovery...
One day I opened my Gas Cubby and it was asking to be setup. Everything was gone.
When I restore the files from the backup, it crashes when it runs. Is there a way to get the data out of the database? I had a lot of entries I do not want to loose. I checked the sync setting and I guess I never set that up properly, so I only have the files from the com.appcubby.gascubbyfram directory. Any help would be appreciated. |
I don't have an answer for you yet, but give me a couple of days to research one for you.
Thanks for your patience! |
Thank you very much!
Well? Have you learned anything?
No update yet. We're still looking into it though!
To clarify, you've never set up sync, so all your data was stored locally on your device and then it just randomly was wiped? |
The data was stored on the device and I did an update and then it was acting empty. So I went to the backup pre the update and retrived that directory.
SO nothing? I'm just SOL?
RacerBear,
Josh (member of Fuelly Team) sent you a message on the 15th and as of this writing hasn't received a response from you. Posting here just in case the message was buried in your inbox, and you see this first! Thanks! |
I got it in the PM here, however, he was just asking me if I setup the sync, and did not respond to all the information I have provided on here. I reiterated it and provided details of the files I have in the backup.
No response from Josh to my Private Message...
