Two change request s
Hello,
Follow a few ideas for aCar /Android: 1.Manage Services: pls add/define the Service items pro car As you know, every factory suggest different kind of maintenance for example for certain cars the oil must be change every 20.000 km certain every 30.000 km. 2. In the Reminder windows pls add the field "Notes" (of course if present) I hope a ..bit clear :) if not pls tell me Thanks |
1. You're wanting to the app to display the manufacturer's recommended service intervals?
This may be tricky, but with enough data, it could be something that could be built in the future. If you're just wanting to edit the default interval to fit your particular vehicle, you can do that from More Options-> Advanced Dashboard and then Services page. 2. As for the Notes in the Reminders section, can you give an example of what type of Notes one might input or expect to see from that section? |
RobertV,
thanks for your answer. Quote:
I agree with you that can't be trick. In word can be easy :D For example: when you add a new car the appl can be ask: "Do you w'd like use the standard services? y/n If yes : it's like now If no : the apl duplicate the standard service items for this last car and later you can be modify ONLY the services items regarding this cars Quote:
"Pls remember : the mechanical, previous next maintenance, must provide special brakes that don't "whistle" :D" or "Pls remember: the best price for the brushes of glass is by....." p.s. I think the display of these notes in the Reminder section: main section for me !! |
this would be a great feature. it would have to be totally customizable. you can set an oil change to be a xxxx miles, and be able to reset the ticker when the oil has been changed. give a warning at a fill up approx 500 miles before the oil change is due. man o man......this would save some bickering between the wife and i. i rarely drive her vehicle, so i depend on her to tell me when the oil needs to be changed. before you know it, she is 1000 miles over-due. if i would have had a notification that it was due, it would have saved some bickering between us. :whistling:
You set the type of Expense, the Intervals in which you wish to be reminded (X miles, or X months). |
If I could suggest an improvement: it would be helpful if service reminders could be set at absolute mileage points, rather than relative to the last service. Those of us who follow the manufacturer's service schedule rigorously (which is more common in Europe than NA) will try to get back on track if an oil change or service is late. So, for example, my Subaru requires oil changes every 6000km, with a more major service every 24,000km. Ideally I want to do my oil changes at 6K, 12K, and 18K, so that the next one falls at 24K and can be done with the major service. But if acar sets the reminder for 6K after the last oil change, this gets out of whack and doesn't line up with the major service. So in the default settings for services, I would like a third option to pin the service to a specific odometer reading or multiple thereof (rather than x kms after the last service).
Thanks. |
