Gas Tracker 2.0.4 Odometer issue
Hi
I'm on the latest iOS running on a 4s. When trying to enter an odo reading during a fuel up and or during a note for a vehicle the odo does not accept more than 4 digits. During the note taking it only saves the very first digit. I saw this was an error on previous versions but seems to still be happening. Any suggestions/help. Thanks and regards |
Which vehicle and what is the Odometer you're trying to input?
I'm trying to put in 12380Km on my KTM690 for the fuel up.
I'm also trying to put in 8330Km in a note for the same vehicle. |
The first fill-up took. Just tested adding a note on my end and didn't run into any issues. Please try again. Does it throw an error message or anything? Can you post a screenshot? |
after logging in to fuelly,com via Gas Tracker app on iphone, it shows wrong data...
- cannot ad odometer data [four digits], and - when old fuellup is it shows no odometer data... https://www.dropbox.com/s/hyqnu656tz...2011.00.01.png |
Ok, well after not winning using the app I entered it via the website when I got to the office.
Is that not perhaps what you are seeing? I think I will delete all the entries and do it from scratch via the app. Will post the results for both the fuel log and the note. |
Ok, so I deleted all the entries for the KTM via this website.
Started from scratch with a new fuel entry using the app.... First screen - no entries - https://www.dropbox.com/s/yx0io53e64...%2044.png?dl=0 Second screen - I typed in the info about to save. The odo shows 1 even though I typed in 12380 after 4 digits it just changed to a 1. Also note the total cost of 225.200. This gets changed to 225.12 when I look at the log after entering it. https://www.dropbox.com/s/n4h8o99xom...%2024.png?dl=0 Third screen - saved successfully. https://www.dropbox.com/s/akqk9bisgf...%2028.png?dl=0 Fourth screen - there's the log entry (and it shows on the website using my desktop browser after a refresh). https://www.dropbox.com/s/8b6szdmv1z...%2034.png?dl=0 Fifth screen - Going back into the entry to view it I get this - note the total cost has changed to 225.12 and the cost/lit is blank or NaN and the odo is all zero?!? Not even the 1 is saved. :) https://www.dropbox.com/s/kiu9828wbb...%2005.png?dl=0 Regarding the note - even though I deleted it on the website it was still listed under notes for the KTM. No way I can find to delete it using the app. Can't edit the note because I get a sync error. Even adding a new note gives the same error as if notes is completely broken now. https://www.dropbox.com/s/dfvwk7jxbo...%2048.png?dl=0 |
Some more observations - the 1 recorded shown on the fuel log entry is the first digit from the 12380 I tried to enter. If I tried to enter 33800 then it retains the first digit which is 3.
The entry from the app does not contribute to the consumption figures on the website. I entered a second fuel log on the website and the odo was 12 thousand something - this should have given me some unrealistic MPG figure because the first entry was 1 on the odo but it did not. Only after adding a second entry (third in total) via the website did it look at the previous odo reading and give me a MPG value. |
for now, gas tracker is useless app
Hi, any plans to get this sorted in the app? If you can't enter more than 4 digits in odo, no use for the app and have to log into the website.
