Can't change mpg to metric
Yeah, so I've changed the settings on the iPhone, and now via the PC itself.
It registers this change but when I pull up the app it still takes data as miles & gallons. Thinking it was a script issue [silly me], I proceeded to use it twice. NOPE. My data is all wrong showing 88L/100km, but the actual entering data portion is all wrong. Takes the wrong readings... Anyone else in the same boat? I just want to monitor my usage... if not, well, it was nice using you Fuelly! -Mike |
Mike,
Sorry you're having trouble! Are you referring to your Subaru? I'm going to assume so since after checking your Profile settings and both of your vehicle settings, your Suby is set to track fuel in US Gallons and Miles. https://www.fuelly.com/driver/01lexpl...es/subaru/edit Follow the link and adjust your Reporting Units and you'll be all set. Thanks! |
Thanks!
10char |
