MPG Not displaying in Log Book
Hi, wondering why my MPG is not showing in my Log Book ? :confused: First one does, next two do not.
Rob |
Your fillup on Sept 12 is marked as a partial fill. When you do not completely fill the tank, no calculation is made for that tank, or for the next one as readings can fluctuate wildly for a partial fill and the next tank. Provided your next fill is a full tank, Fuelly will start calculating tank averages with your next fillup.
If the Sept 12 fillup was a full tank, and marked as a partial on accident, just go in and edit that entry, and remove the check from partial tank. Then calculations will be provided for the two entries. |
Hi, thanks for the quick replay. My 2nd fill up was a partial fill up. The fill up today was a normal fill up. When I did it via the android app i'm sure it said best MPG at 53. something. Wondering why I have no graph yet either in the recent fill ups ?
Because fillups that don't calculate don't generate a point on the chart either.
Ah, I see, thanks for the help. One more thing (sorry to be a pest) I have noticed that in my recent activity display it says I had my best MPG of 53.1 (says two because I deleted & input again when nothing on the graph showed) but does not show that on the Log Book or Basic Stats etc
I see a best of 37.5. Maybe you're viewing some cached data? Try holding the CTRL key while clicking refresh.
Hi, everything is sorted now thanks for your help & info. I had misunderstood what a partial fill up meant. My second fill up was not a partial fill up. Changing that has put everything else in line !
Yes, a partial fill is when you purchase fuel, but you don't completely fill the tank.
