It is also known to work in Nissan CA series engines which were used from about 1984->1997 (as long as they have fuel injection) (Nissan Bluebirds etc), also Nissan Micra / Nissan March 1.0 / 1.3 litre twin cam engines. As I have tested it on two different Bluebirds and one Micra :)
So basically all Nissans should work with it. |
On my fuel injected Bluebird, the vacuum gauge was very closely related to the MPG. In 5th gear, no matter what speed I was going, a certain position on the vacuum gauge would equal a certain MPG, at 30 or 80mph. In 4th gear, the same position of the vacuum gauge used more fuel (because the engine was turning faster). I got the best economy by changing gear ASAP as I accelerated. My final v. good economy was by 'lugging' from 800-1200rpm, then changing down, until I got to about 35mph in 5th, the cutting the engine until the speed drops back down to 25mph in 5th (which is about 800rpm). The RPM is one of the main things that has an effect on the MPG. |
If you take a photo of the engine bay, that may help? (Or, maybe easier, people on this site might know if the car has injection or not).
The SuperMID will work in any car that has fuel injection (single or multipoint), although some cars have a weird two-injector 'single point' system that it won't currently work with. You also need an electronic speed sensor - it may well be included somewhere on your car, or Yoshi sells plug-in ones if you don't have one. |
