Filling up in litres
Hi
When I go to the add a fuel up screen, it will only show gallons in the amount box - and I want to use litres, as that is what we use in the UK. I've gone into site preferences, display units - and tried all of them without success. Am I missing a setting somewhere? |
Looks like you got everything covered. I checked your vehicle's settings too.
Can you take a screenshot of you attempting to add a fillup please? |
Thanks Robert - I re-entered the vehicle from scratch and now it works fine - with litres showing!
I tried to delete the thread but can't find the delete thread option. Regards |
No worries, I'll go ahead and close this topic then. Normally you can edit your first post and then submit it to be deleted. There might be a time limit to edit posts however. Haven't checked in awhile.
Regardless, glad it's working! |
Robert, if you carried over the settings I had in place on the old GasSavers forums, I had it set so the original poster could edit for 15 mins. There was no option for deletion, if the user wanted a thread deleted they needed to contact a moderator or admin.
That's likely still the case then. Thanks!
