-   -   Any point in knowing the charge left in the battery? (https://www.fuelly.com/forums/f8/any-point-in-knowing-the-charge-left-in-the-battery-1705.html)
SVOboy 02-11-2006 10:47 AM
I found a little write-up showing how to make a meter for this and I was wondering if there was really any practical reason for doing this in terms of gas mileage xor anything else.
Fire away!
n0rt0npr0 02-11-2006 10:59 AM
Nah... The charging system
Nah...
The charging system is self regulated.
krousdb 02-11-2006 12:16 PM
Re: Any point in knowing the charge left in the battery?
Fire away!
Do you mean a volt meter or a meter to determine the state of charge of the battery? Normally you wouldn't care much about this unless you plan of shutting your engine off at a stop light or coasting with headlights, stereo, windshield wipers on, and then starting up again with the starter. All of those things will drain your battery. If your trips are relatively short, your alternator may not be able to charge your battery sufficiently. Day after day the charge drops until you can not longer crank it over. In that case, you might find a voltmater handy. If you drop between 12V with no load, you really should charge your battery.
kickflipjr 02-11-2006 12:24 PM
If you can tell the charge
If you can tell the charge in the battery it could help detect a weak/dying alternator.
GasSavers_Diemaster 02-11-2006 08:31 PM
why not just post the link
why not just post the link and let us determan if it's cool or not :P
SVOboy 02-11-2006 08:54 PM
It's just a schematic,
It's just a schematic, almost exactly like the afr thing but it reads the range of voltage of the battery rather than 0-1.
Matt Timion 02-12-2006 12:11 AM
Re: It's just a schematic,
Post up the schematic. It would be very beneficial to those who want to do an EV conversion someday. EV fuel gauge.
krousdb 02-12-2006 04:14 AM
IMHO (in my honest opinion), a voltmeter wouldn't make a very good EV fuel gauge. Batteries in general, and NiMH chemistries in particular provide most of thier capacity in a fairly tight voltage range, typically 1.25 to 1.0 volts per cell. The perfect analogy would be a narrowband O2 sensor. A voltmeter would really only show full charge, charge but not fully charged, and dead battery. Perhaps the new Lithium ion chemistry is different. I don't know much about LI except that they can get very hot and are very explosive if charged or discharged properly.
JanGeo 02-12-2006 04:33 AM
SOC
SOC State Of Charge in pb lead batteries 13.5 float voltage 12.9-12.8 full 10.4 dead when measured no load resting for several minutes. Li-Ion 4.25-4.20 full 3.0 dead pretty linear again measured no load. The Li-Ion often use an alcohol based electrolyte DUH Flamable!! and Lithium reacts with water.
SVOboy 02-12-2006 07:53 AM
Sure thing. I gotta go shovel some more snow so I can afford the car parts I want, but when I get back in I'll dig it up from my computer and post it.
IMHO I always thought "H" meant humble!
