MPG not being calculated...
Not sure what is going on, but the last two fill ups it did not average my MPG.
make sure you didn't mark a fill up a partial.
I show the last 2 (Oct 24 and Nov 26) calculating MPG...
I have been using Gas Cubby since June 2008 and it has always kept track of my MPG. It stopped calculating MPG in November and as of my last fill-up on 12/12/2014, it still does not calculate MPG. What happened?
https://www.fuelly.com/gascubby/suppo.../gcexport.html |
1 Attachment(s)
Change the file extension to .csv
Please add .csv to the file extensions that we can upload. |
The 3 of the last 5 fill-ups were marked as Partials. Partial fill-ups will not calculate MPG. Prior to that you have all but one marked as partial back until August 2nd. If these were marked in error, simply edit and remove the Partial fill-up marker and your MPG should calculate immediately. Thanks! Edit- I also didn't realize you had already moved your data to Fuelly, and you can easily see the fillups that were marked as partials here: https://www.fuelly.com/car/toyota/4ru...01D/298987/log |
So, there is no point of indicating a partial fuel-up....weird!
