Imported data off by one day in Fuelly app
Hi,
I'm a new user here, moving over from the unsupported/abandoned Accufuel. I've imported my data from a CSV spreadsheet through your portal, and have a problem. Although the data is correct on the web site, everything shows up 1 day early in the iPhone app on my 6 Plus (iOS 8.1.3) For example, my most recent fillups, show online as having happened on 1/16/2015, 1/13 and 1/3 on the website. However, they show up in the app as being on 1/15, 1/13, and 1/2. This goes all the way back to the start of my data in 2007. Fillups entered in the app do show up with the right date online. Any ideas? Thanks, Rob |
I see in your preferences you have your timezone set to UTC.
https://www.fuelly.com/driver/riffraf/edit If this is incorrect you can change it. Fuelly expects the time/dates in your CSV to be in your timezone and then they are converted to UTC and then converted back depending on the user's timezone for display. I would recommend you set your timezone to that of how your fuelup dates are stored in the CSV, do the import, then set your timezone back to the correct value. |
Thank you, sir! That fixed it.
